跳转到主内容
Ethernet is a widely used computer networking technology that allows devices to communicate with each other over a network. It is commonly associated with twisted pair cabling, which is a type of cable that consists of pairs of insulated wires twisted together to reduce interference.
Ethernet wire connection to wall mounted box
Where exactly can I put the two wires that come from telephone line to this connection box?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @natnaelfisseha
Usually there's 4 pins in an RJ45 socket when used as a telephone handset socket and the telephone wires connect to pins 4 and 5 (the middle two pins) when viewed from the front of the socket i.e. pins count Left → Right 1→8 but 1 & 2 and 7 & 8 are missing
Assuming the holes leading to the pins (where the wires are in) number 1, 3, 5, 7 on the back row (closest to pins when viewed from the back as seen in your image) and 2, 4, 6, 8 in the front row then the telephone wires would connect to the red and green wires.
If the telephone service is connected you should hear dial tone if you plug a telephone into the socket.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Natnael Fisseha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 183
