跳转到主内容
加入维修社区 - 创建账户
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
Record/playback only works when tape speed is set to 2.4cm
Everything seems to work just fine, albeit the audio sounds a bit wobbly, when the tape speed is set to 2.4cm. However, when i set the tape speed to 1.2cm, nothing works and only the battery light comes on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @isaakgilissen
Try replacing the drive belt.
Search online for Sony 3-377-420-11 to find suppliers that suit you best.
Also use some Isopropyl Alcohol 99%+ (available from electronics parts stores) to clean the capstan, pinch roller and the record, playback and erase heads in case they're creating a drag on the tape.
Here's the service manual that may help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Isaak Gilissen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 158
