跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Cannot install certain games but others install just fine?
So I have been trying to install GTA V and usually somewhere between 20-50% completion it crashes and says corrupt data. I tried safe mode and rebuilding, the disk is clean(brand new actually) I tried a hard reset etc etc and just replaced the hard drive in my ps4, but it was doing this before I replaced it as well(it’s actually the reason I replaced the hard drive) The copy of the game is also brand new as I mentioned. So what’s going on? I’ve seen people say buy a new copy but this copy is literally brand new, I took the shrink wrap off and it immediately did this? Is there anything else to try I’m missing? I’m actually also running in to this problem with Elden Ring as well, again brand new and Assasins Creed Collection. I just installed RDR2. Seinko and persona 5 with absolutely no problems. It’s not a memory issue as there’s plenty left. I thought maybe it was because of the game sizes but RDR2 is bigger than 2 of them. Thought maybe game age but Assasins Creed collection is nowhere close to new. The only thing the 3 games that won’t work have in common that I know of is that I got them as Christmas Presents haha. I’m at a loss as to what is going on, I’ve tried everything possible that I found on google now and none of it worked.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you tried this trick (works for some)? First delete the data that already got installed (corrupted) then you take the console offline (disconnect from the internet completely) then reinsert the disc and let it copy files from the disc first. Once that's done (if it completed successfully) reconnect to the internet and then let the game receive updates etc. Sometimes this happens because the game is trying to "install" from the disc and download and install patches at the same time, causing a corruption.
How about this trick (works for some)? When the data is installing from disc, right when it stops/freezes/crashes but before it errors out, eject the disc which will pause the install. Reinsert disc to finish from where it left off. This sometimes works.
As for GTAV, this "problem" goes all the way back to the original launch. I'm pretty sure Christmas isn't the problem. :)
Good luck.
这个答案有帮助吗?
得分 0
2条评论:
I actually have had it disconnected from the internet every time I tried to install any of them :/ I’ll give your other suggestion a try but that may be tricky since they tent to error out at different install percentages every time. Appreciate the advice. I actually did get past the “initial” install of elden ring. Thought the game had fully installed, started playing, and got to the end of the tutorial to be met with, cannot proceed until game finishes installing. It crashed at 65% 🙄 delete the file and now we’re back to can’t even install it enough to get to that point.
完成的
Ouch. I know they love to push that "you can start playing before it's even fully installed" stuff but...I recommend ignoring that fluff. Always just let the things fully finish installing first. :( Personally I've seen too many issues with data corruption and HDD's (xbox one and ps4), eventually I switched to SSD's and never had corruption problems ever again to this day. You could try using an external usb hard drive (or ssd) and set it as your default install location and see if that changes anything. Let me know if you have success. Good luck.
完成的
添加一条评论
i too am getting this error and just wanna ask if it works now or not?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean Bartley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 55
