跳转到主内容
Repair guides and support for the Lenovo Ideapad 310-15IKB, a midrange consumer laptop released in 2016.
5 个问题 查看全部
Is this actually the maximum RAM for this system?
I have a Lenovo 310-15IKB, and I am trying to max out its specs. I see here that the max amount of RAM my system can handle is a whopping 20GB. However, Lenovo, the manufacturer, says in the manual for the system that it only supports 16GB. Which is the true maximum RAM?
My second question is a little complicated. The laptop has 4GB of DDR4 RAM soldered to it's motherboard, and it also has a RAM slot for removable RAM. I currently have a 4GB DDR4 RAM card put in the slot, bringing the total to 8GB. This means I currently have the benefit of Dual Channel support. If I buy a 16GB RAM stick and put it in that slot, bringing me to 20GB, will I still have Dual Channel support?
I am very technically experienced, so I can buy the right RAM and install it if I know the answer to these two questions. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Gosh, how many laptops do you have?
完成的
I have a LOT of computers and phones. I have a Toshiba NB305, a Lenovo Ideapad 310-15IKB, an HP 14-cf2112wm, a Late-2013 13" Macbook Air, a Late 2013 11" Macbook Air, a 2019 12.5" M1 Macbook Air. That is just the laptops, I have phones, tablets, calculators, MP3 Players, and desktop PCs as well. Also, I have spare parts to fix any problems on these machines that emerge as well, such as RAM cards, HDDs, disc/disk drives, and more.
EDIT: I currently have my eyes on getting a fairly old Macbook Pro, most likely one of the 15" Non-Unibody ones from the early 2000s.
完成的
添加一条评论
1个答案
已选择的解决方案
@eucador Crucial has confirmed that this laptop can support 20GB RAM. Crucial confirms this by performing real world tests.
As for the memory, it should still support dual channel mode.
Sources:
https://www.crucial.com/compatible-upgra...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mcniner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 201
