跳转到主内容
Dead screen, but phone still vibrates/powers on; what's wrong?
The screen started to dim until its dead/black. The phone still vibrates when turned on (or if performed a hard/forced restart), and the alarms that were set still works/rings with the screen dead/black. It charges at 9.2V/1.45A according to a USB tester. What's wrong with the phone? What can be done to at least be able to recover the photos from the phone? Is it possible to repair the phone or is it beyond economic repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Although you can't guarantee a remote diagnosis 100%, there's a very high probability that the screen has simply failed and needs to be replaced. OLED screens are actually very delicate and it doesn't take much to kill them. Water damage, being dropped, or even being bent by sitting on them while they're in your pocket can all damage the display, and of course it's also possible the electronics just plain failed on you.
In any event, given that the phone is showing every indication that everything else is working, it would be well worth your time to replace the screen. Most vendors will allow you to return a display that hasn't been installed so you can buy it first then just plug it in without installing it and verify that it comes on and works before you finish tearing the phone apart to replace it. If it doesn't work at that point you can pack it back up and return it for a refund, otherwise you'd continue with the repair and there you go, Bob's yer uncle!
With Samsung phones there are two ways to replace the screen. The official/recommended/suggested method is to replace the screen and frame as a single unit; that way there are no concerns about getting the new screen securely glued to the frame since it comes that way. The downside is that you basically have to gut the entire phone and move all the parts to the new frame. The good news about that is that Samsung actually makes it pretty straight-forward and easy to do that; unlike an iPhone where that kind of operation is very difficult.
Here's a guide showing you how to do that kind of replacement. It's in Spanish but if you use it with the Chrome browser, the automatic translation makes it quite usable even if you don't speak Spanish.
Manuales / Samsung Galaxy S10+ / Full screen with chassis - Nadie Me Llama Gallina
The other way to replace the screen is to separate the OLED from the frame and just replace that part. It's really no more complicated than the full frame method, but it does require a different set of instructions, plus you have to deal with glue and resecuring the display to the frame. You'll save a couple of bucks on the part, but probably make up for that with having to buy glue. Here's the iFixit guide to that repair.
Samsung Galaxy S10+ Screen Replacement - iFixit Repair Guide
One note myself and others have run across in repairing Samsung phones is to be very careful with the rear glass. It's very thin and easy to break, and is glued down very well, so follow the instructions, use lots of heat and work slowly and carefully to avoid cracking it like myself and a few others have done. They're not expensive and easy to get, but why replace it if you don't have to?
Update (01/25/24)
Ah, I did think of one other possibility as the source of the problem. There's a proximity sensor built into the phone, usually near the top of the display, that senses when you put the phone up to your face to talk on the phone. When that happens, it blanks the display. A malfunctioning proximity sensor can be telling the phone that it's up against your face all the time and thus blanks the screen.
Note that this should only affect the screen while you're on a phone call, but it is possible for a bad sensor to mess things up all the time. Once again, this would require board level repair expertise, something most of us aren't equipped for, but for completeness I wanted to add this.
这个答案有帮助吗?
得分 2
2条评论:
What are the chances that an IC on the mainboard is the culrpit, like the Samsung S2D0S05 Display Power Managment? (From this teardown: https://www.techinsights.com/blog/samsun...)
完成的
@mylesuy It's always a possibility, but to be honest it's really rare for a black screen to be caused by anything other than the screen. You can, of course, take it to a repair facility for a diagnosis which shouldn't cost too much money if you want to be certain, but I'd estimate the odds that a new screen will fix the problem at better than 90%.
The other side of that coin is the fact that the screen repair is something you can do yourself if you so desire, while the board level IC replacement is definitely beyond the capability of most of us, myself included.
完成的
添加一条评论
最有帮助的答案
Hi @mylesuy
If you wish to check if it is the display module or not here's the service manual that will help.
Go to p.105 (of 136) to view the display troubleshooting flowchart.
There are also board layout diagrams that will help you to locate the part mentioned in the flowchart (use the browser's search function - Ctrl + f) and a parts list as well in case it is a faulty board component and not the display module.
这个答案有帮助吗?
得分 2
1条评论:
Nice find on the service manual. I've been working on too many Apple products so it usually doesn't occur to me to try and locate a service manual, lol.
完成的
添加一条评论
添加你的答案
Myles Earvin Uy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 73
总计 276
