跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 个问题 查看全部
Why doesn't tub completely dran after spin cycle?
Tub agitates, spins, drains, but some water is left at the end of the spin cycle. Why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @ericanders82064,
What is the model number of the washer?
How much water is left in the tub at the end of the spin cycle?
完成的
添加一条评论
1个答案
So the washer works fine except doesn’t drain all the water. First take notice of the drain hose. Is the water coming out fast as usual? If not, there could be a partial blockage in the hose or the water pump maybe going out. Also, the water valve maybe leaking water back into the tub.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EricAnderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
