跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
Intermitent disconnection after battery replacement
Hi!
Last month I started having problems with my Switch Pro Controller. After a while without playing I couldn't get it to charge properly and at the end it stopped charging at all. I checked the battery and it was swollen so I order a replacement and change it as soon as possible.
However, after replacing the battery the controller has started to turn off intermittently. Sometimes just clicking any button turns it on but sometimes it takes it a while to work again.
Is the battery defective? Or it may be caused by an additional problem that needs a different fix?
Please let me know if you need aditional info about it adn thank you all in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would start by looking at the battery contact, check that no acid or other contaminates are causing your problems. If your problem persists then maybe try disconnecting and re-pair it to the switch
这个答案有帮助吗?
得分 1
1条评论:
I have cleaned both battery contact an device contact without success. Also repairing but it isn't a sync problem, the controller turns off. Is there a way to check if the problem is coming from a faulty battery or some part of the controller?
完成的
添加一条评论
添加你的答案
Rodrigo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 85
