跳转到主内容
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Why is the MBP 14" not turning on?
Hey everyone, I've got a MacBook Pro 14" M2 from 2021 that was running smoothly until recently. Now, it won't boot up no matter what I try – I've checked the power cable, the charger, and held down the Touch ID button. Frustrated, I decided to open it up and disconnect the battery, and that seemed to do the trick. However, here's the catch: I have to repeat this process every morning because it refuses to boot again.
I've experimented with leaving it charged and turned off, but nothing seems to change. It's almost like the battery drains overnight, and then it struggles to recognize the charger or boot. Could this be related to macOS Sonoma? I've heard it has some battery consumption issues. Should I consider rolling back to Ventura, or could this be a battery-related problem? Currently, the battery is at 86% capacity with approximately 700 cycles. Any insights or suggestions would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First, run Apple Diagnostics and Coconut Battery.
Using Apple Diagnostics
Coconut Battery
这个答案有帮助吗?
得分 1
3条评论:
Take a snapshot on what CoconutBattery shows you and paste it here so we can see it as well.
完成的
Forgot to mention that I did run Apple Diagnostics and show no issues, will try this coconut battery and will came back with the result
完成的
Sorry for the delay posting the results of coconut battery
完成的
添加一条评论
添加你的答案
Alejandro Peñafiel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 128
