跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
3GS backlight our after screen repair
I replaced an LCD screen in a 3gs and and the backlight isnt coming on.
The lcd is brand new and I turned the phone off when I replaced the screen to prevent a short.
The phone hasnt been updated in awhile so could a restor fix this?
I tried resetting the phone setting but nothing changed.
The only other thing I can think of is the coil shorted but the phone was off when I worked on it and there is no water damage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you tried a different LCD? It just could be that the one you received is bad. Sounds like you took all the precautions during the fix, so I don't see any other issues besides a bad part.
What happened to the original LCD? If it was showing backlight before, then a new LCD should as well.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 637
