跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 个问题 查看全部
Ram sockets seem faulty
I have a problem with my iMac’s ram sockets.
If ram is at all installed on the right sockets (viewed from front of unit), it throws a 3 beep error.
If ram is only installed on the left side (viewed from front of unit), the system chimes and boots up.
Any solutions, suggestions, or advice is much appreciated! 🙏
Here are the specs by the way:
-27 inch display
-Mid 2011
-A1312
-EMC 2429
-Intel Core i7-2600 SR00B (upgraded) (original i5-2500s)
-500GB SAMSUNG SSD
-32GB RAM before cpu upgrade worked fine (4x8gb elpida ddr3 sticks)
-16gb also worked fine (2x8gb)
Update (01/24/24)
I am not trying to push it to 32GB. It worked before, so I tried to it, but did not work. I tried it with all of the ram I had, including the original 2, 2gb sticks of ram that came in the Mac.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I think you fell into a known trap! At the time period of this system (Sandy Bridge) Intel was having problems with their support chips and there interaction with the CPU. If I remember correctly Apple used the SR00C chips.
I would get the newer rev chip instead if you are going to push the RAM to 32GB otherwise you’ll need to stick with 16GB which is the supported limit or roll back to the i5 CPU.
这个答案有帮助吗?
得分 2
6条评论:
Okay, should I try the intel core i7-2600k SR00C?
完成的
@electronicartel - Why are you pushing the system to 32?
If the system is working with just the two SO-DIMMs (16) maybe it’s just the best answer if you need the more powerful i7
完成的
完成的
@electronicartel - So the question is - you can’t get any RAM to work that you are sure is the required specs and are sure are fully inserted?
完成的
Not on the one side, but all ram works on one side
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Electronic Cartel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 55
