跳转到主内容
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
How to clean the inside components of my steam deck safely?
HI!
I was wondering how I can clean the inside of my steam deck, I never done this before and since I usually use my deck in a very dusty outdoor business, the inside of my steam deck is very dirty.
Thank you in advance for the help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @milanorwolf
Here's the ifixit Steam Deck repair guide that will help.
It details how to open the console and remove all the parts.
The first thing that you should do when you start is to make sure that you have a clean work bench and are organized having the correct tools to do the work and enough containers etc to place in any components that you remove, especially any screws etc. so as not to lose them
After opening the console, first disconnect the battery as soon as it can be accessed so as to nullify any electrical problems from occurring when working inside the console. Mechanical damage .e. tools slipping etc is another matter so be careful and concentrate on what you're doing.
Wearing a wrist strap connected to an earth point will also minimize any potential for ESD damage to the sensitive electronic components on the board if you happen to accidentally touch them.
To clean off the dust etc, use a soft brush and gently brush it loose and then use a vacuum cleaner (lowest setting) to remove it from the boards etc.
When finished reconnect the battery just before closing the case for the last time.
If you strike problems, stop and think about it first instead of rushing headlong into trying to solve it as you may cause unnecessary damage. This forum is full of questions from users who tore cables, broke plug latches, stripped screws etc most probably due to impatience more than anything else.
Slow and steady and I'm sure that you'll be OK.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Milanor 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 85
总计 1,009
