跳转到主内容
加入维修社区 - 创建账户
Model A1046 or A1095 / 1280x854 screen resolution
Keyboard Cable Replacement Possible?
I recently replaced my DC/Sound board and upon reassembly, the keyboard stopped working. The track pad works fine. I would like to know if it is possible to replace the ribbon only, or do I need to replace the keyboard or top case to eliminate them before I put in a new logic board. Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
From what I see and remember the keyboard and cable are replaced as one unit. But the good news is you do not have to replace the top on this model to replace the keyboard.
Here are the instructions to replace the keyboard:
PowerBook G4 Aluminum 15" 1-1.5 GHz Keyboard Replacement
Here is the keyboard. You need to select the right one though. One is with Backlighting and the other is without Backlighting:
http://www.ifixit.com/Mac-Parts/PowerBoo...
You will need a small tipped philips head screwdriver. One like the following would do:
http://www.ifixit.com/Tools/Phillips-0-S...
Good luck
这个答案有帮助吗?
得分 2
添加一条评论
Thanks, at least I now know what I need. I hope replacing the keyboard will take care of the problem. It will certainly be cheaper than replacing the logic board! It would have been nice if you could just replace the ribbon, cest la vie!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,661
