跳转到主内容
主板和 CPU 维修指南。
170 个问题 查看全部
Replace LAN port on Dell E5550 laptop motherboard
Hi All, this is more of a search question. I have a Dell E5550 laptop. The LAN port, which is integrated into the motherboard, is worn out and I want to replace it. I know I can replace it, but I cannot find the part. Does anyone have any links or insight into where I can find this part. There is a number on it of S5267. Tried to search it and came up empty. Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @sthomaschllc
Here's an image of the LAN port from the schematic for the motherboard that may help.
The LAN port part number is Santa130456-511 but I had no joy when searching for it but I found this when searching for a 13 pin RJ45 socket which may be suitable.
Here's the owner manual for the laptop. Go to p.37 to view the procedure to remove/replace the systemboard, which you most probably will have to do when removing/replacing the port.
(click on image)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 43
