跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
426 个问题 查看全部
WTW4715EWO goes all the way to spin cycle and doesn’t spin. It resets
WTW4715EWO Model number goes all the way to spin cycle and doesn’t spin. It resets back to wash. I then have to dial to drain and spin to finish each cycle. I replaced the springs. Nothing. Did you figure out what it was?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @lauramiles
Here's the tech sheet for the washer.
Run the diagnostic tests as shown on p.2 of the guide and check if any error codes are displayed.
On p.3 there's the Fault/Error Code Display Method chart that shows how to interpret the status LEDs to know what the code is.
The fault error code and description for the codes are found on p.6→p.7.
If there is a faulty part that needs replacing, here's a parts list that is useful.
Locate the wanted part in the parts diagrams to find the manufacturer's part number listed with the part. Then search online for the manufacturer's part number only to find suppliers that suit you best.
Hopefully a start to find out what's wrong.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Laura Miles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 21
