跳转到主内容
加入维修社区 - 创建账户
A2116 / 2019 / 3.6 GHz 四核 i3、3.0 GHz 六核 i5 或 3.2 GHz 六核 i7 处理器。发布日期为 2019 年 3 月 19 日。
Display is not working after SSD Upgrade
Hello. So I just upgraded my iMac (21.5 4K 2019) with an SSD
How can I tell if either display cables on the iMac LCD is bad? My iMac display won't turn on after doing the SSD upgrade and reconnecting the LCD to the logic board. I'm using an external display and everything is working except for the iMac display. If I go to settings - display the built-in display is recognize. But again nothing shows up in the screen - not even the apple logo when turning it on.
Also the Facetime Camera is working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @carlossosa72884
I'm not sure of the problem here since you did an upgrade but you probably damaged the display or it's cables while you upgraded the SSD, Since your computer recognizes the built in display the wires should be working so the display may have to get replaced.
Let me know of any developments
这个答案有帮助吗?
得分 0
2条评论:
Hi @ihave0idea.
Thanks for the quick Reply.
So I tried disconnecting the black power cable. Not the eDP cable but the other one, to see if anything change, and I got the same behaviour. No display, Display shows up in Settings and Facetime Camera works.
Also I checked the LED Lights on the Logic board and 4/5 turns on. I believe the 5th light (the one that does not turn on) is the display backlight/power.
iMac won't boot, black screen and no external display
So not sure if that's the damaged cable.
由完成的 分享
HI @carlossosa72884
Thanks for replying, Like i said before. You may have to replace the LCD panel on the mac
由完成的 分享
添加一条评论
添加你的答案
Carlos Sosa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 319
