跳转到主内容
Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。
255 个问题 查看全部
My screen is dead, where should I begin for repair?
My steam deck worked perfectly fine, and now my screen is "dead". I put it in quotation marks because I'm unsure how to successfully describe it. The screen remains black after being powered on (and charged). I can plug the deck into an external monitor and the game is there, so the deck works. Also, while plugged into an external monitor I can also use the touch screen and it is responsive, leading me to believe the screen itself is fine, there just is no picture. I have tried multiple different methods of resetting it and nothing has fixed the screen. Should I replace the screen or a cord? Any suggestions would be greatly appreciated. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
it is an LCD display so it has a backlight. Did you do a backlight test with a flashlight?
There is a backlight driver in there. Here is a bunch of info you may need.
这个答案有帮助吗?
得分 0
1条评论:
I tried and didn't see any images.
To confirm, a flash light test is basically just powering the device on and holding a flash light close to the screen at an angle to see if there is any "attempt" at an image being shown, correct? I did not see anything that would lead me to believe it is trying to portray an image.
完成的
添加一条评论
添加你的答案
AHibbs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 71
