How to remove the drain hose from a SMEG DWAU6214X Dishwasher
I have a leak in my drain hose right near where it passes through the rear dishwasher wall. I want to remove the hose and attempt a repair or replace. The hose passes through what looks like a removeable darker grey panel 5x12cm. Lower in this panel it also has the mains cable passing through it. I have looked but cannot see how the panel pops out. I'm sure I have to remove the panel and the hose would then slide out the top. As an aside is there a way to repair the hose which has a split inside the rib. I suspect I will have to replace it though.
Does the end that connects to the pump just pull off, push on? There look to be 2 O rings on this end of the pipe.
I believe I need this part "758973779 Smeg Dishwasher Drain Hose LS08 DWA Series 2 Meters"
It looks like the hose has a hard coller where it passes through the back panel.
