motor does not stop to trigger the final spin cycle
Have similar problem. All cycles including spin cycle after wash. Problem happens at the end of the rinse cycle, tube totally drains, but the motor does not stop to trigger the final spin cycle, just continues to pump all the way through spin cycle without a spin. motor stop at the end leave clothes very wet, need to run a second spin....
Now did find out that if I lift the Lid at the beginning of spin cycle (stopping the motor) and close the lid it activates the spin cycle, Wala clothes come out dry... It appears Lid switch is working properly, I have replace the clutch no change, all drain hoses are clear no obstructions. seems have to do with sensing end of rinse/drain to trigger motor to stop the start at begin of spin trigger final spin.
Kenmore 80 110268525501
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
