跳转到主内容
Repair and information guide for the Samsung RF267AA** refrigerator, a bottom freezer model with a through-door ice dispenser and both drawer and door access, first introduced in 2008. This page covers information for model numbers matching the pattern RF267AA**.
Freezer won’t get cold!
I have tried resetting the panel, cleaning and inspecting all coils, fan runs, compressor runs, fridge gets cold but freezer won’t! Feels like I’m getting air through the vents but won’t get cold! What else do I need to troubleshoot?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Haven’t had the chance yet! Will get back at you asap!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @junemtnman
Here's the RF267AA Fast Track Troubleshooting guide that may help.
Run the Self Diagnosis diagnostic tests as shown in the guide and check if any error codes are being displayed.
Hopefully a start.
这个答案有帮助吗?
得分 1
5条评论:
Jayeff thx for the answer! I’m going to troubleshoot as soon as I can. I think it has something to do with the refrigerant not getting to the proper spot if that’s possible? I am no expert with refers, that’s for sure! I appreciate your time and answers, the troubleshooting guide is going to help me a bunch I feel! Anything else you can think of don’t hesitate please.
完成的
@junemtnman
What is the actual temperature in the freezer compartment?
Your model has two evaporator units, (where the cold temp is produced) one in each compartment (refrigerator and freezer) and the refrigerant flows through both in series connection i.e. compressor → → freezer evap unit → refrigerator evap unit → condenser coil → compressor.
If it were a refrigerant problem then it would normally affect both compartments
完成的
55 degrees freezer 36 degrees refer
完成的
@junemtnman
Did you run the diagnostic tests?
完成的
完成的
添加一条评论
添加你的答案
junemtnman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 118
