跳转到主内容
加入维修社区 - 创建账户
这是一款 Apple 原装连接线,在时代演变下将 USB to Lightning 连接线中的 USB 端改为了 USB-C 端。
How do I know which wires connect to which?
My dog chewed through my USB-C to USB-C cable that came with my 2020 MacBook Air. I’ve tried to connect all the wires by matching their colours but I’ve plugged it in and it still doesn’t work. Since there are three red wires I wondered if the order they are reconnected in matters. I am an amateur and don’t really know what I’m doing so any advice would help out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sorry, you really need a new cabled here.
Did you ever see a Cray micro computer? All the wires are White! The cable vendor doesn’t need to follow reason. And you can’t assume Red #1 is equal to function to Red 2# line.
The other factor here is besides power there are data lines and the construction of the cable is likewise important for signal integrity.
这个答案有帮助吗?
得分 2
2条评论:
Do you think if instead of joining the two parts, I should stop the wires on one end and solder it to the other? Would that be a better alternative?
完成的
@jesuskhan - OK, this is how I would do it. I would use an Ohm meter and measure one line and the connectors contacts to isolate the active pin. Repeat for the other side. Doing each wire one at a time. And you still need to re-join the shield connection as it’s electrically active as well.
Really a lot of work to band-aid a cord which won’t last very long and could create a safety issue. I would replace the cord it’s not worth the effort.
完成的
添加一条评论
添加你的答案
Jesus Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 503
