跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Hard Drive and Blade Flash Drive upgrade
Hi.
Can I upgrade the 1TB HDD and the 32GB Flash storage in my iMac 21.5" 4K Retina 2017?
I am opening up the iMac to upgrade the RAM & HDD to SDD and would also like to upgrade the 32GB Flash storage with OWC Aura Pro X2 SSD
I will be running MacOS Ventura 13.6 and I believe the Firmware combines the 2 Drives into 1? I intend to install the OS on the new SDD and leave the OWC aura-pro-x2-ssd for use as explained in https://en.wikipedia.org/wiki/Fusion_Dri...
Im unsure if I'm on the right path as there are a lot of conflicting advice.
Thank you
John
Replace or upgrade the PCIe solid-state drive in a variety of Macs.图片
产品
OWC Aura Pro X2 SSD
$199.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hey there,
Regarding the hardware you've chosen, you should be on the right track. I'll also link you to iFixit's recommended RAM and secondary SSD upgrade kit. You should be completely fine if you've got your macOS Ventura installation image ready.
Max your iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) with 32 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac.图片
产品
iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) Memory Maxxer RAM Upgrade Kit
$251.99
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit.图片
产品
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
$72.99
这个答案有帮助吗?
得分 0
1条评论:
My main concern I would appreciate advice on is upgrade of the 32GB Flash storage with OWC Aura Pro X2 SSD?
And I would prefer to go with an Internal SSD rather than an External SSD as is would be less prone to failure and I will the iMac fully torn down
Any advice would be appreciated
John
完成的
添加一条评论
添加你的答案
John Loch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 133
