跳转到主内容
Repair guides and support for your LG TV.
1350 个问题 查看全部
My Oled tv doesn´t turn on after bezel was bent,
Hi
I recently acquired an LG oled TV (OLED55CX6LA) for free. The tv won´t turn on after
the bezel around the screen was dented (very small dent!).
The TV only goes to standby and when I try to turn it on the relay clicks once and it goes back to standby. I tried disconnecting the four panel connectors to the T-con board one by one to no effect. I then disconnected the lower cable connecting the main board to the t-con board and then turned on the tv. Still no picture but the relay didn´t click when the cable was disconnected.
Any ideas on what the issue might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
At first this sounded like a possible power supply issue but since there was no relay click after you disconnected the mainboard I would suggest you check for any damages on your mainboard and your T-board. I believe the issue might be revealed there. Maybe the dent caused minor but critical damage?
这个答案有帮助吗?
得分 1
1条评论:
Hi, thank you for answering. I will take them out and let somebody look at them (I have very limited experience with electronic repair).
完成的
添加一条评论
添加你的答案
Ágúst Ingvarsson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 73
