跳转到主内容
加入维修社区 - 创建账户
主板和 CPU 维修指南。
Is PCI-E Slot replacement a thing?
Hello Everyone! I hope everybody is having a good day!
My main PCI-E slot is pretty worn compared to the second one that is not used and is giving me bad connection with my GPU.
My PC would randomly restart without warning or bsod
I have troubleshooted each components Ram, CPU, GPU, PSU, SSD, HDD without issues (used my brother's PC as test bench) and it just points to one component the Motherboard which I think is around 3yrs old now.
I have also done multiple driver uninstall and reinstall.
This is the second PCI-E which is unused
This is the main PCI-E slot and by looking at the pins the spacing between the upper pins and lower pins is a lot larger compared to the unused PCI-E slot (first photo)
Specs:
RYZEN 5600X
MSI X570 CARBON AC WIFI
CORSAIR VENGEANCE 32GB 3600Mhz CL18
Deepcool AIO
ADATA 512GB SSD
WD Black 8tb HDD
EVGA 1200P2 (1200W Platinum)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @allanjuntilla,
What is the make and model number of the GPU card?
Can't you install it in the unused PCIe slot?
完成的
@jayeff Hi, I definitely can but it would run at a lower performance about -10%.
I seem to have forgotten to put the GPU, It is an ASUS TUF 6800XT (Non OC)
完成的
添加一条评论
1个答案
最有帮助的答案
@allanjuntilla
The board having only 1 PCIe 4 x 16 slot limits the options I suppose
Replacing PCIe sockets is not an easy job, especially if you haven't done it before.
I would suggest that you get hold of some old boards first to practice on, so that you know how much heat to apply when unsoldering them from the motherboard and then resoldering in the new one.
Get it wrong and you can cause more problems than what you originally have.
Here's a video that may help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Allan Juntilla 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 59
总计 958
