Why does my phone keep restarting
Keeps restarting every 3 minutes and says panic full cpu 3
This should help you read the panic log and diagnose the issue. https://www.youtube.com/watch?v=C2687jnf...
From what I've seen in my shop, the most common cause for a 3 minute restart is an issue with the charge port. Just be aware this piece of software isn't always accurate, and does require further diagnosis, it's a tool used to help narrow down what the issue could be.
这个答案有帮助吗?
iPhone 14 keep restarting if there's an issue with the wireless charging/rear mic/flash.
You can reproduce it by disconnecting the flex cable.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 205
post the full panic log
由 daniel 完成的
Well, probably don't need the full log, but at least the first page or so.
由 Jerry Wheeler 完成的
