跳转到主内容
The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
Wire in the way of 2nd SSD slot
I'm planning to put an M.2 2280 in the 2nd SSD slot, but there's a wire in the way of it. Where's a good place to put the wire?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Can the m.2 go over the wire? If not, then I would just peel the tape attempt to route it around the drive. It looks like it has enough slack to go around the end but only you could verify. Look at the attached picture for what I mean
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the advice. I put it in today and it did go over the wire without any sort of bend or trouble.
完成的
添加一条评论
添加你的答案
Tufty 13 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 136
