跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Ipad charges when off but won't charge when booted up
Hi fellow repair people.
I have stumbled on a puzzling situation after replacing a battery on an ipad 4 A1458
The ipad seems to charge perfectly fine while off but when it is booted into the OS it doesn't charge but it is recognized by both Itunes and my laptop. It also seems to have a hard time recognizing the home button.
Any tips, tricks or insight into the root problem would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I’ve had this problem too, so we just basically shut it off to charge it once we plugged it in. But i didn’t notice any problems with the home button use though. This was an older iPad so I wasn’t worried about it as I was given it to somebody.. but when it stops charging, it’s probably a tri starship. If you having a tri star/ hydra checker you can test it. I do think I recall that on one of the nine pathways there was one or two that weren’t within the proper parameter of the device, but I didn’t feel like I wanted to go and change the chip to see .because that’s where the charging system goes through to charge the battery .Just a thought.
这个答案有帮助吗?
得分 1
4条评论:
I'm only a hobby repair guy but it seems to me that it can be. how much does the tristar checker cost?
完成的
Thru ifix it was 130$ but i not even sure they sell them anymore.
完成的
tested the ipad again today. it recognized the charger for a second while on and then not. can it be as simple as the charge port?
完成的
That could be. Especially if it is older and had a lot of use of the ipad. Which necessitates plugging it in and out.
完成的
添加一条评论
添加你的答案
Markus Norstrøm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 138
