跳转到主内容
Food processor from Vorwerk manufactured and first distributed in 2014/2015 (Europe/US).
Dial jumps when selecting speed temp etc
I have one of these, it is working fine Except for the dial. Selecting an adequate temperature or time is kind of a minigame. For one dial step sometimes goes back and forth, sometimes does the right thing or sometimes makes a big bump. I was bearing with it because it was just an annoyance, but has been three onions that I only wanted "chopped" and I ended with them utterly pulped because the dial decided it.
I guess I only need to clean contacts, but before try to tear it I was hopping if someone here has some experience, If it is an easy task or if does not worth it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @carlospenas
I don't know how easy it is, but here's the ifixit Thermomix TM5 Teardown guide that will help to gain access to the speed controller encoder switch (example only to show possible cost)
Here's a link to another answer on ifixit that describes how to clean encoders but it was an easier to open type that what appears to be used in the Thermomix. Volume Control Knob Acting Strange
With encoder type switches usually it is a build up of gunk inside the switch that causes them to malfunction and opening them up and cleaning the switch contacts with an electronic contact cleaner spray (example only) usually restores its operation. Although looking at the switch image in the link above it doesn't appear to be as easy to open it as some other types of encoders. Also the one in your device contains an on/off switch as well which makes it more difficult to clean.
If you decide to replace the selector switch, search online for Thermomix TM5 speed controller switch to find hopefully find other suppliers that may suit you better.
If you can't find a suitable supplier check if there's a part number on the switch itself, and try searching for that.
这个答案有帮助吗?
得分 2
1条评论:
I just disassembled it following the steps from the video. I disconnected the speed controller encoder, I removed the black plastic piece, cleaned everything up and put it back on it's place. Problem solved, no need to order a replacement.
完成的
添加一条评论
添加你的答案
Carlos Peñas 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 57
总计 696
