跳转到主内容
Repair Guides for Vacuums, Mops, Sweepers, and Gutter Cleaners by iRobot.
20 个问题 查看全部
My iRobot keeps saying error 26
Hi I changed the filter, bag , and brush also checked if anything is stuck any where. I reset it but it does the same thing . Comes out of the charging station maybe about a foot or two out then stops and says error 26
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My Roomba (Ruby) would come out of her charging station, move maybe 10 feet and shut down with error 26. I replaced the motor suction fan and the battery since I had her apart, cleaned her up real nice, put her back together and “look at Ruby go!” Working perfectly. Lots of great “how to” videos on YouTube and so easy to disassemble and reassemble.
完成的
添加一条评论
7个答案
最有帮助的答案
这个答案有帮助吗?
得分 1
1条评论:
Same here, I fixed this issue after replacing the motor of the sucction fan and the error got away. Also, I got difficulty to separate the fan and the motor had to put quite some strengh to have it out.
One more thing the fan has some broken fan blade, not sure I can replace this fan some days.
Looks like nobody is selling this specific part.
完成的
添加一条评论
Error 26 on a Roomba means the vacuum is experiencing insufficient airflow. Here are some things you can try:
  • Clean or replace the bin filter
  • Remove the bin
  • Inspect the vacuum port
  • Remove any foreign debris
  • Press and hold the clean button for 20 seconds
  • Wait 60 seconds
  • Press the clean button once
You can also try opening the motor assembly and clearing dust.
Can you share your exact model number? The model number is printed near the left wheel, on the underside of the robot.
这个答案有帮助吗?
得分 0
1条评论:
Fixed the error on my i7
Is the motor working too hard to turn the fan blade?
I opened up everything to get to the dowel of the fan blade.
I tried turning it by hand a bit firm when I did.
The dowel which has approximately 3 washers (two are together) on it.
After removing all of them, I put 1 drop of oil and graphite powdere onthe dowl where each one of the washers isand where they touch each other or the housing. (especailly important is where the dowel attaches to the plastic housing)
After this I put it all back together and turned it again by hand which moved more freely than before.
It has been working GREAT ever since.
Hope this helps
完成的
添加一条评论
I have done all of the steps above that you recommended including taking a q tip and cleaning the fan blades. Still same problem
这个答案有帮助吗?
得分 0
1条评论:
What is your exact model number? The Cleaning Head Module probably needs to be replaced. If you can give me the model I can find the right part for you!
完成的
添加一条评论
Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Just fixed my i8 error 26 by removing fan only not motor and cleaning. Runs good now. Will install a better fan that small and dont get stuck.
这个答案有帮助吗?
得分 0
添加一条评论
Hi all
On my side I have fixed this issue by replacing the motor of the fan, it was apparently tired and replacing it was the solution for fixing this issue.
I purchased the part on Aliexpress
hope that help.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
After cleaning filter、lubricating the motor, error was still there. I Finally bought a Clean Head module for replacing, but still got error 26.
Anyone has idea how to fix this problem?
Thank you
这个答案有帮助吗?
得分 0
1条评论:
I would recommend to try replacing the motor fan. This what fix the error for me.
完成的
添加一条评论
添加你的答案
JWilamo 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 241
总计 4,812
