跳转到主内容
Repair guides and support for your Philips TV.
243 个问题 查看全部
TV Philips 42pfl6057h/12 blink 2 times and not turn on
Good evening, I have a TV as described that won't turn on and the led, after about 5 minutes that it's powered on, flashes twice endlessly.
I opened the back panel and measured if the voltages feeding the motherboard were present.
So at the output I have 3.3 and 12 volts and the standby voltage goes to 3.3 then to zero every time the switcing starts because when the TV is on I hear a very faint hissing of the switcing transformer and the processor touching it gets warm, after a while it cools down, the very faint hissing is heard again, the processor gets warm again, everything continues until the led starts blinking.
The voltage measurements I made on cn4 of the attached schematic.
Do you think the fault may be in the power supply or the mainboard ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @albertocauzzi
Here's the service manual that may help. I realize that it is for the 47" model so hopefully it is the same for your size TV.
A 2 blink error is a Layer 1 error code which according to the manual indicates a problem with the SSB board (mainboard) - see the error code table on p.35/165
If you want to narrow it down further you can try to activate the CSM mode in the TV to see if you can get a Layer 2 fault indication - see p.27 activate csm mode
On p.40 it shows the ssb board replacement procedure.
Hopefully this is of some help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alverman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 42
总计 105
