跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
786 个问题 查看全部
Not booting, stuck on charging Battery icon
Hey all, I'm trying to get this mbp to at least boot but I'm having no luck.
Since it didn't come with a power adapter, I'm using an official Apple Magsafe 1 85W adapter with the magsafe 1 to 2 converter.
When trying to start it normally, it jsut gives a black screen with the red battery charging logo. I left it like this with an amber charging light on the magsafe cable overnight and came back next morning but it still had the same issue. Unlike other macbooks of this generation I've worked on (2015 13 inch Pro) it just immediately shuts off when the power cable is disconnected rather than show the 'connect to power' sign.
I tried disconnecting the battery and connecting it to the power adapter but that didn't fix the problem either. It behaved the exact same - as if it thought it had a battery to charge.
Pram reset does nothing, but when SMC is reset I can get it to chime. However it starts with fans on full blast and the progress bar only reaches 30% before it shuts off again and bootloops. This behaviour occurs regardless of whether the battery is connected. If I disconnect the charger and try start it again, it won't chime unless the SMC is reset again.
I've tried booting into safe mode after the SMC reset which gets the progress bar further but it still shuts off at about 80%. Recovery won't start and internet recovery gives me an error.
EDIT: Diagnostics reported back the codes PFM001 and PPT001.
I've also tried booting from a known working bootcamp ssd I had used before but it just hangs on the Windows loading screen.
Has anyone else had the same problem and what should I do?
EDIT 2:
I've gotten the macbook to verbose boot and a shot of the log right before it shuts off:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The error codes are the following:
  • PFM001 - There may be an issue with the System Management Controller (SMC)
  • PPT001 - The battery was not detected.
These make sense at you took the battery out.
As you are getting past POST I suspect you have a bad drive or the OS is corrupted.
Using a second make I would create a bootable thumb drive with the correct macOS this system needs. Booting up with a BootCamp setup drive adds another layer of confusion.
It’s also possible the discrete GPU is failing. Are you able to boot up in Target Disk Mode (pressing the T startup key) if you get the Thunderbolt Icon on the screen that tells the GPU has a problem.
这个答案有帮助吗?
得分 0
8条评论:
Hi, thanks for the response!
This laptop doesn't have a discrete GPU as far as I'm aware of, it's the integrated gpu model. I'll try out target disk mode, but I did also get both PFM001 and PPT001 when the battery was connected.
I also tried the option+shift+command+R recovery mode to reset it back to factory OS, but that had the same issue as the regular boot itself after the spinning globe loading bar completed, where the apple logo loading bar would reach 30% and then it woud shut off and bootloop.
完成的
@billybob91887 - Please give the Target Disk Mode a try that will help.
完成的
Just tried target disk mode and I got the thunderbolt icon moving around the screen. I don't have a thunderbolt 1/2 cable though... What should I do with this now?
完成的
I've also just made Monterey install usb which exhibits the same issue as booting from the internal SSD where it shuts off after loading 30% of the bar
完成的
Now I've been able to start in single user mode, but beyond that I'm not really sure what I can do in this mode...
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Billy Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 188
