Washer does not get past the wash cycle.
My Kenmore 110.23102 washer does not go past the wash cycle. The tub fills, the lid locks, the agitator moves, then there is a long pause followed by a humming sound (is this the drain part of the cycle?). I have taken the drain hoses off and checked them, I removed the pump and measured 15 ohms and took the cover off the pump and the impeller moved smoothly. The pump goes directly into the bottom of the outer tub - I have not disassembled that yet to check for clogs. Any suggestions or recommendations greatly appreciated. Also, if I hold the cancel button for 3 seconds, which I think should initiate drain it makes the same noise.
2条评论
Hi @smofinch,
Please confirm the full model number of the washer as there are 3 different models beginning with 11023102 and they're not all the same as to how they're wired and what parts are used?
由 jayeff 完成的
Thanks for your response @jayeff,
So sorry - the full model number is 110.23102310.
由 smofinch 完成的
