跳转到主内容
加入维修社区 - 创建账户
Mac硬件 - 由苹果公司制造的任何Mac 电脑周边,包括外置光驱,电源适配器,电线,转换器等。
Why won't Battery door will not open on Apple Remote Model No A1156?
Would like to replace the battery in my Apple Remote. No matter what I try, the push/release mechanism will not release the battery tray. Any way to get this door open without damaging the device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
need to get a paper clip or sort, and push down into the little hole and it flips open, to replace battery. battery type is a Panasonic CR2032 3V
Good luck
这个答案有帮助吗?
得分 2
2条评论:
I use the jack of my headphones, pushing it all the way down. It's thin enough, and sturdy, and doesn't scratch the button as a paper clip could do if you've got jittery hands.
完成的
This worked. You have to push harder than you would think.
完成的
添加一条评论
This seems to work only with the new "silver" remotes. I cannot find any way to open the original White ones. Does anyone have information on disassembling the white A1156 EMC 2086 models?
这个答案有帮助吗?
得分 0
3条评论:
Stefano's tip worked for my white A1156 EMC 2086 models
完成的
Ok Steve, I too, have the identical remote... and had trouble opening it. After reading the above comments, let me just confirm that you need to use a semi pointed object to press in the small round circle located on the bottom of the remote.... I used a standard size nail (as in hammer) and finally the battery tray popped loose. Note that the circle will be hollow when popped out... If somehow, the remote became sticky and the spring mechanism is gummed up, do what you need to do... like place the bottom one inch (1") in hot water being carful not to submerge the button area into the water... this should free up the geewie stuff freezing the spring loaded tray. Good Luck
完成的
I found that a handheld hair dryer on the "low" setting worked pretty well and didn't risk water intrusion. The hot water method didn't seem to unstick the drawer tray sufficiently. These are now old remotes, but we misplaced a newer one, and the Gen 1 remote seems to work fine with a Gen 3 Apple TV.
完成的
添加一条评论
In case anyone still needs an answer to this question here is the link to Apple Support answering this question. http://support.apple.com/kb/HT1306
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Mattson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 4,747
