跳转到主内容
加入维修社区 - 创建账户
A modern, mini, edition of the Nintendo Entertainment System, launched on November 2016. Also known as the Nintendo Classic Mini NES in some markets.
nes classic won't power on
i bought a faulty nes classic that i discovered won't power on. i checked for voltage with my multimeter and am getting 5 volts at the port and on every component i should be but still no power. what am i missing? it's a european model if that makes a difference
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
5v seems very low for a console
这个答案有帮助吗?
得分 1
5条评论:
5 volts is all it needs since it's the mini and not the og nes
完成的
@techlord yea just checked the power adapter specs, maybe a power button issue
完成的
i checked the power button and reset button with my meter and they're functioning properly
完成的
@techlord any bridging pins in the hdmi port ?
完成的
hdmi port looks fine with no pins touching, micro usb port looks fine with no pins touching
完成的
添加一条评论
External Power supply is 9VAC for 1.5A. After the diode rectifier bridge the supply goes to 13VDC.
3 tensions are used from this 13VDC power --> 9VDC, 12VDC and 5VDC this last one thru a LM805 egulator.
As a troubleshooting method you can connect a lab power supply tuned on 13VDC directly on the VIN leg of LM805 the regulator + GND, or on the big capacitor following the diode bridge.
If the console is still dead, the problem is elsewhere.
这个答案有帮助吗?
得分 0
1条评论:
i don't have it anymore but it wasn't the og nes, it was mini. never figured out what the fault was. when i had it and checked for voltage i was getting 5 volts everywhere i should have but still no power and the switch was ruled out since it did work
完成的
添加一条评论
添加你的答案
Cheap gamer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 63
总计 741
