跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 个问题 查看全部
iMac beeping 3 times and has a blank screen
Hi there,
I have just started up my iMac and it keeps booting with 3 small beeps, 3 long beeps then 3 small beeps. I have been on the phone to apple and they are no help. This just keeps on looping and I have taken out the RAM and reinserted. I would appreciate it if I could get some help on this.
TIA
Taza
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@taza Here are a couple things you could try:
  1. Try removing the RAM completely from the iMac
    • Does it still give you the same sequence? If so, then try each RAM module one by one to check if it works or not. Maybe one of them doesn't work which would cause the iMac to beep.
    • It's also possible if someone placed the RAM into the slot in the wrong way and damaged a slot, so try the other slots if you suspect one of them doesn't work.
  2. Try SMC reset
    • Unplug the power cord, wait 15 seconds, attach the power cord, wait 5 seconds, then power on.
    • It may not work but it has helped for some people
  3. If you see a loading bar, then the iMac is probably updating its firmware, which could take a while
I hope this helps :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Taza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 24
