跳转到主内容
加入维修社区 - 创建账户
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
Display cannot be replaced
Hello, i tried to replace my cracked display. When sliding the display unit up there was still metal frame on the main unit. I know i do not have a genuine display installed so could it be that the preowner just glued it in with the wrong glue? Or can i still remove the metal frame with force? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
did you remove the pentalobe screws on the bottom of the phone, if yes then use a hair dryer to heat the adhesive under the metal plate and try lifting it up
完成的
Thanks Daniel. Yes, i did. I was suprised the metal plate stayed on , but i could easily open the display.
I will do it according to your recommendation and will heat it up to hopefully separate it
完成的
Ok. It really worked. Thanks a lot for your answer!!!
完成的
@philippsch91253 glad you got it sorted
完成的
添加一条评论
1个答案
最有帮助的答案
thats the backplate from the old screen, it needs removed before installing the new screen
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Philipp Schneider 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 160
