跳转到主内容
加入维修社区 - 创建账户
Flipper Zero是一种多功能的多工具设备,设计用于黑客攻击、调试和试验各种电子小工具和系统,如传感器、接收器和其他电子组件。
Can the USB port on flipper zero be repaired or replaced?
My flipper zero's USB-C port still works for charging, but no longer works for firmware updates, serial communication, file transfer, or as an HID device. If I wiggle the USB port then I can get it recognized briefly but after trying a dozen different USB-C cables and 4 different PC's I've concluded that it is a hardware issue. Is a repair feasible/possible by re-soldering the port connection to the board, or are the solder points too small?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
sounds like its got a disconnected solder pad or maybe a couple, it is repairable but it might need micro jumper wires if the solder pads are damaged
这个答案有帮助吗?
得分 2
添加一条评论
It sounds like your USB-C port might be damaged. I would look inside the USB-C to check for damage (Bent pins or burns). If you see any damage, I would attempt to contact Flipper's Official Support to see if they can repair your device if it is under warranty before attempting to replace the port itself. If the device isn't under warranty, try updating the device via Bluetooth before replacing the port.
Also, to answer the core of your question, it is possible, but you will need micro-soldering skills/equipment.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tropical Topic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 42
总计 1,002
