跳转到主内容
How do I replace Hinges on HP Chromebook x360, model 14a-ca0036nr
I want to confirm the required screen hinge part number for an HP Chromebook 360, 14a-ca0036nr. I was looking for a video or tutorial on to replace the hinges. If I can't find one, I may try to post a video when I try this Hinge replacement on a HP Chromebook x360, model 14a-ca0036nr.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @brenick19097
Here's the maintenance and service guide for the HP Chromebook x360 14a-ca0000 series, that should be applicable to your model as well.
Go to p.37 to view the procedure to remove/replace the display assembly. This will allow you to see how to remove the hinges.
The hinge part number (see Item #11 on p.15) is M15311-001. Search online for the part number only to find suppliers that suit you best. Just to verify the part number, it is the same number as shown in the parts list for your exact model.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
brenick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 53
