跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
206 个问题 查看全部
CPU overload after possible short on motherboard.
My MacBook Pro A1990 has been running pretty hot when I’m gaming so I decided to open it up and lean out dust inside.
I originally was going to take out the fans and clean them but I quickly decided that was going to be far more than I felt like dealing with last night, but in the process I had a pair of tweezers I was going to removed the speaker cable and had forgotten to first unhook the battery! Ugh! My tweezers momentarily connected with nearby components and sparked. Did I short it out?
I see now marks. The laptop was very dusty so I just used compressed air to clean it. However, upon putting it all back together it seems to be having issues every time I try to use my external monitor or play a game.
Both things resulted in the CPU going from below 1% to near 70%. I’m thinking maybe a shorted something out or maybe blowing the dust further under the logic board… I’m at a loss. Anyone have any thoughts as to what might have happened? Everything else works fine.
Update (01/02/24)
I should add that I did a big system update the same day this started happening. I’ve since noticed that my MacBook starts up with high fans and high CPU but then settled down when everything loads. I also noticed my CPU kick up when scrolling preview. It’s so weird though because I can have preview running and everything is fine but as soon as I’m scrolling through a PDF on preview the CPU starts throttling.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well I can tell you the dust is not the worry 😰
It does sound like you’ve damaged some of the circuitry of the logic board. So now you’ll need to find someone with Mac systems component level diagnostics skills with the needed tools and parts to fix your system. Otherwise it’s time for a new logic board which is likely more expensive.
Can you tell us where a-bouts you live country and nearest major city, maybe we can aim you to someone.
这个答案有帮助吗?
得分 0
4条评论:
That’s what I was afraid of. 😔
I’m in central IL near Peoria
完成的
@elizabethhitz - Let me look into it.
完成的
@elizabethhitz - Sorry we don’t have anyone listed in the area which does board level repair. But in upper NewYork we have a great specialist which I think is your answer! iPad Rehab Jessa does Mac’s too so don’t let the name fool you. Give her a call and tell her we aimed you to her.
完成的
Thank you, appreciate your looking into it
完成的
添加一条评论
添加你的答案
Elizabeth Hitz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 85
