跳转到主内容
Repair and disassembly information for Samsung's flagship S20 Android smartphone, released in March of 2020.
Make one working phone out of two partially working ones
I have two phones:
Phone A [Galaxy S20 (G980F D/S)] where most likely the motherboard + charging board need to be replaced (damaged during port cleaning, phone wont charge through wired nor wireless, quickly displays message saying phone gets too hot. Very rarely it will charge and then works fine for a while. Changing out the charging board did not fix the issue)
Phone B [Galaxy S20 5G (G981B/DS)] with a cracked screen and back glass
So my question is how to best proceed. My first thought is to remove all internals from phone B and place them into phone A, but I would prefer to have the 5G capabilities and am not sure if there are any necessary components (such as 5G antennas?) in the shell.
Any advice appreciated, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
there could be different ways the internals of both models are, im not sure off hand. as for phone A did you use a genuine charge port as some copies dont have the required sensors
这个答案有帮助吗?
得分 1
6条评论:
Yes, the charging port was purchased directly from Samsung.
完成的
@cinnamon7272 take the wireless charging coil off and try cable charger only to see if it changes
完成的
This yields a similar result; The phone started charging, but quickly (at 2%) stopped with a message the phone was overheating, which is behaviour that also sometimes happened with the wireless charging coil still attached. I do feel some heat which I would consider overheating from the top center of the phone, either at the very top of the battery or (as it seemed to me) just above it, at the motherboard.
完成的
@cinnamon7272 are you in europe as the g980f is a euro model
完成的
Yes, I am indeed in Europe
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Cinnamon7272 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 111
