跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Fell on the ground, its starts but doesnt show on tv
Hey guys, so i was playing on my xbox one s and it randomly fell on the ground with a BIG smack, and after i tried to start the xbox it started, but it doesnt show anything on the screen. Me and my stepdad looked at the xbox and everything was fine except the HDMI port, i think it may have been damaged while falling to the ground. I would show some images but dont know how to show it here
If any of you guys can help me it would be much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
sounds like the hdmi port is damaged and that should be it sorted
这个答案有帮助吗?
得分 2
2条评论:
any chance you could help me how to fix it or change it?
完成的
@joonaseric62525 i can tell you which tools you would need but trying to explain how to replace the port wouldnt be easy through a forum and watching a few videos on you might be easier for you to watch, tools you will need will be.
soldering iron
hot air station
flux
leaded solder
solder wick
99.9% isopropyl for cleaning flux after repair
teardown guide Xbox One S Teardown
video: https://www.youtube.com/watch?v=mEDYT7sZ...
also do not try lifting the port out until solder has fully melted and because its a think pcb you will need a hot air station that can reach 450-500c
完成的
添加一条评论
添加你的答案
Joonas Erich Iloste 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 19
