跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
210 个问题 查看全部
Blank screen no Touch Bar and keyboard light and no external screen
Hi everyone, I have a MacBook which when the lid is opened the screen, keyboard back light and touch bar stay off, when I press the caps lock the green light comes on and off and when I triple press the Touch ID button I hear the voice over turn on and off, I even tried to connect a external display and it doesn’t show anything.
Any idea on how to fix this issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Try using an external keyboard, mouse & display (using the system in clamshell mode, display closed).
See if your system is able to work that way.
这个答案有帮助吗?
得分 0
7条评论:
Hi Dan, I tried that and so did the Apple genius and it still didn’t respond to anything plugged in at all
完成的
@hassan538 - Can you give us some background on what happened leading up to this.
完成的
The MacBook was working perfect fine when I left for holiday and then it was working the day I came back but then on the next day I opened the lid to find the laptop screen touchbar and keyboard lights didn’t turn on at all,
完成的
There no physical damage to the MacBook at all, I took it too Apple and they said no physical damage just wear and tear on the lid and back plate
完成的
@hassan538 - So one day it just didn’t respond? No liquid spills or sat in a puddle. Battery was fully charged or was it in need of charging? Didn’t bang it, drop it or have something heavy sat on it?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Hassan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 38
