跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
Tap to wake function not working after screen replacement
Just replaced the screen on my iPhone 11 Pro with the OLED screen kit from ifixit.com. Everything on the phone is functioning perfectly except for the tap to wake function. I've checked and it is currently enabled in the settings menu. Just wondering if this is a recurring problem with these replacement screens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Were you able to fix this? I’m having the same issue.
完成的
添加一条评论
2个答案
已选择的解决方案
It is a recurring problem with some replacement screen , contact the support team at iFixit and ask if the function should work with the screens they sell, if it is the case ask for a warranty replacement, if not you are stuck at this point.
这个答案有帮助吗?
得分 2
添加一条评论
Hey, it's great that you replaced the screen on your iPhone 11 Pro! Sometimes, after a screen replacement, certain functions may not work as expected. It's possible that the tap to wake function is not fully compatible with the replacement screen. You could try restarting your phone or even reinstalling the screen to see if that helps. If the issue persists, you might want to reach out to the customer support at ifixit.com for further assistance.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steve93 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 126
总计 1,902
