跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
XS Max original screen swap
Hi, I have 2 iPhone XS Max, one is on iOS 17.0 and 16.3.1, because 16.3.1 has the advantage of jailbreak, but that iPhone has a broken screen, and I want to get the screen from 17.0 iPhone to 16.3.1
Will there be any problems afterward?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
no the ios is on the logic board and has nothing to do with the screen
这个答案有帮助吗?
得分 2
2条评论:
So in theory I can use an original screen from one iPhone to another and not lose any features like Face ID or True Tone?
完成的
@kiyoshi1407 true tone will need copied, face id is to do with the front flex cable which will need transferred over
完成的
添加一条评论
The only issue you should encounter will be that you will lose the True Tone function on the screen. There is a way to copy what's called the MtSN number from the original screen to a replacement, but it requires a device programmer, something like the JC V1SE or the QianLi iCopy. Those start at about $85 USD, so it's entirely up to you whether that one function is worth the purchase for what will most likely be a one time use.
You might check around and see if there are any local repair shops that would do the programming for you for a reasonable cost, but otherwise you'll have to decide how important that feature is to you. Other than the MtSN number, there are no other parts pairing issues with swapping screens on an iPhone XS Max.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kiyoshi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 29
