跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
After replacement of screen and dock, display shows only blue stribes
Hello,
I dropped my Iphone 4 and it cracked, and in an attempt to change the front screen, I ruined the dock connector. I got a new screen and dock, and have replaced them both, but unfortunatly now I cant turn on my phone. The sounds go on when i turn it on, but the display shows only a black screen with one blue stribe in the middle.
I miss my phone, pls someone tell what could be wrong?
Thx, Louise, Denmark
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hi Louise,
It sounds like the LCD screen is damaged. Depending on the level of quality of replacement part it could have been faulty to begin with or you have damaged it during installation.
I would recommend taking the phone apart and inspecting the front assembly again. First check that the flex cables are not damaged (which i doubt they are in this instance).
Then check the back of the LCD screen - a common mistake is to screw the left most screw of the wifi EMI shield in too tightly. By doing this the screw puts allot of pressure on the top left of the back of the LCD screen and creates an indent - causing permanent damage to the LCD screen.
Please see this picture for a return we had where the customer had done just this.
http://db.tt/HGtXhrS2
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Malou86 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,882
