跳转到主内容
Repair guides and support for your LG TV.
1350 个问题 查看全部
The tv will not power up The standby light come on then turns off
Hello I have a LG 55in TV that will not power on, I’ve tried the rest procedure and it still acting up. I’ve notice that the Red standby light is not on. And when I attempt when I tap the power button it will light up and then turn off, I can hear something in the tv click off. The Model number is 55LW5300-UC
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @lgperforma41709
Here's an image of the Power-up boot check troubleshooting flowchart from the service manual that may help.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
Oh no, it sounds like a hassle with your LG TV! Firstly, check the power source, make sure the outlet is good, and the cord isn't damaged. Try a different outlet and do a power cycle - unplug for 10-15 mins, then plug and retry. Ensure your remote has good batteries, and also try the TV's power button.
If it persists, check for physical damage and consider a factory reset. If all else fails, contact LG support, especially if it's under warranty. If not, a professional technician may be needed. Be cautious with internals unless you're savvy. Good luck!
这个答案有帮助吗?
得分 0
2条评论:
I tried and Check all what you said. I need a service manual with a wire diagram so I can test the circuit boards and internal connections
完成的
@lgperforma41709
The service manual was linked in my answer above.
完成的
添加一条评论
添加你的答案
lgperformance@hotmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 39
