跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
What did I do to the audio cable?
I was trying to follow a guide on how to replace the keyboard for my Mac and when I tried to remove the audio cable I think I broke it. Is there a way I can fix this? I attached some photos.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It looks like you pulled the pins out of the connector. In your picture the connector housing is still seated in its socket on the logic board, but the wires and electrical contacts have been pulled out.
I would try to remove the empty connector housing from its socket, then see if you can properly install the two pins before re-seating the connector. It's possible the housing is broken, but I can't tell from the photos. If so, you can probably source a replacement from Digikey or Mouser if you or somebody else can identify the part number. It also may still together well enough that it will work without replacement. Regardless, make sure you get the order of the two pins correct.
I suspect this happened because you tried to pull the cable to the side instead of pushing it up and away from the logic board. It doesn't look great but is fixable.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
BluRepairs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 68
