跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
iPod wire torn while screen replacement, how to fix?
I am replacing a iTouch and apparently I pulled the inner metal plate and it took along this little black piece with an attached blue and red wire. Well the blue wire tore and I'm wondering how I can fix this problem. Here is a pick of it so you know what I'm talking about.
http://i44.tinypic.com/2817xnl.jpg
Also, I was wondering what this specific piece is called and what is it for?
Which part is the wire connected to because I see two possible connection spots?
So heres an update, the wire I tore was the blue speaker cable. Does any one know how to fix it?
Update
There is some type of glue or clear rubbery substance covering the wire where it is soldered. How should I remove that in order to start unsoldering the old stuff. I'm trying not to damage anything else.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Alright sounds like a plan, I will let you guys know how it goes. I need to figure out how to solder though, I have never done so in my life!
完成的
the exact same thing just happened to me while changing the screen on my 4g...did you manage to fix yours? and will it still work without fixing the wire?
完成的
添加一条评论
2个答案
已选择的解决方案
You should be able to look at the board and see where it was soldered. If it is too short you can cut a piece of the same gauge wire, slip on a piece of heatsink, twist the wire onto the blue one, seal it with the heatsink then solder it back to the board.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It goes on the other side of the red wire. If you can make the wire reach that far it may be salvageable, if not you will have to replace the whole component. You have to de-solder and re-solder the connections.
这个答案有帮助吗?
得分 1
1条评论:
Makes sense, but which metal circle does it attach too? I would think the only one it actually reaches so the very first one down?
完成的
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,260
