跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s found after 10 years, but stuck in apple logo.
So my mom phone my sister's OLD phone in a storage, its a white iPhone 4 (A1332), it hasn't been charged in like a DECADE, the phone is running iOS 7, at first, there was no signs of life, but then after cleaning its port multiple times (yes, it was very dirty) it didn't come up with a dead battery logo, but instead was on the apple logo, it would stay on there for 10 minutes and then the apple logo would fade away with a white line, then goes dark, then flashes white. This thing hasn't been charged in YEARS AND YEARS. Please help! The power button is also stuck. The home button isn't though.
Info Provided
Its running iOS 7-9
Cracked
Model: iPhone 4
Model Number: A1332
AT&T model.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Honestly, if you really want to get this thing going, your best bet is to buy a functional phone of the same model and swap the logic board into it. That will eliminate all the broken parts and leave you with just the motherboard as the only part to deal with. It will either work or not, but at least you won't be chasing down rabbit holes.
The thing is, with that phone being so old and not even supported on some carriers (Verizon) any longer, you can almost certainly pick up a working one cheap, especially if you find one that's iCloud locked - which you won't care about since you'll be swapping the motherboard.
这个答案有帮助吗?
得分 1
1条评论:
I need the data, my sister has gave me her passcode for this phone, so she obviously gave me permission to look at the data. I hope its just the battery or charger doing it. Its multiple chargers all in one cable, and its very short.
完成的
添加一条评论
添加你的答案
Annothy ceka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 87
