跳转到主内容
Sonos Play:5 (Gen 2) was introduced in late 2015 and discontinued in early 2020 with the launch of it's successor, the Sonos Five. The Play:5 (get 2) and Five are identical except for improved cosmetics and newer processing hardware with more ram. The speaker drivers, amplifiers, and DSP are the same.
3 个问题 查看全部
My Sonos Play5 stopped working.
My Sonos Play 5 stopped working. There was no impact or other external physical incident that could be responsible for its sudden demise. The little white light on the top does not come on when plugged in - it is just dead!! It is possible to repair a Play 5? I live in Vancouver, Canada - does anyone know of a electronics repair place that could help solve this mystery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is more than lightly that there has been a voltage spike and that the T 3.15A fuse mounted directly on the PCB near the power socket has blown. You need soldering experience and a good idea of what you are doing to dismantle the unit to test that this is the case. There is is sometimes a varistor blown too and it is a good idea to at least check - if not replace - the bridge rectifier and two adjacent 100mf 400v capacitors too. Hope some of that helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Disgruntled Sonos Play 5 owner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 131
