跳转到主内容
The Toyota Prius is a hybrid electric car designed by Toyota. The third generation, sold from 2009 to 2015, introduced a new body design with a lower coefficient of drag.
14 个问题 查看全部
Solar panel on the roof dosen`t work
Hi. Got a "old" Prius 2012 (third generation) and having problem whit the solar panel on top that going to cool down the car while in a hot sommer day. last summer had problem that dosent work and was wondering any info or manuel to see the connetcons
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @knutknutse66571
Here are some images taken from the 2009-2015 Toyota Prius service manual showing the solar ventilation electrical wiring diagram that may help.
(click on images)
Also just verifying that you are allowing enough time for the solar powered ventilation system to start operating as shown in this video?
这个答案有帮助吗?
得分 1
3条评论:
wow that was fast XD
Yes given it some time and standing in direct sunlight to avoid any obstruction. not been a problem until now this summer. Will go through it today and see if I can find the error through the images
完成的
@knutknutse66571
Good luck.
I also tried to find the location of L104 solar ventilation relay (see image #2) but it is not shown in any fuse box diagram that I found online for the model. Maybe they showed the fuse boxes for the models that didn't have the feature installed or it is installed somewhere else. idk.
Also apologies for the poor images, they were the best I could manage ;-(
Hover your cursor over the image and then click on the magnifying icon. When it opens, click on the image again to enlarge it further and see if that helps.
完成的
no problem anyting helps ;)
Possibly found out that there must be something with the solar panel itself on the roof that stopped working since I can't find any direct faults. but someone who knows where those wires go without demolishing the whole roof. So I can check the voltage/watt on the solar panel produse any electrical current
完成的
添加一条评论
添加你的答案
knut knutsen (Skullspirit) 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 47
总计 170
